5 best sleep strategies to avoid SIDS
February 6, 2023by Shruti Dubey
5 Best Sleep Strategies to Avoid SIDS and Keep Your Baby Safe
What is SIDS?
Sudden Infant Death Syndrome (SIDS) is the sudden and unexpected death of an infant under one year of age. It is the leading cause of death in infants between one month and one year of age. The exact cause of SIDS is unknown, but it is believed to be related to a combination of factors, including sleep environment, sleep position, and medical conditions.
How to Reduce the Risk of SIDS
The best way to reduce the risk of SIDS is to create a safe sleep environment for your baby. Here are five strategies to help you do that:
1. Place Your Baby on Their Back to Sleep
The American Academy of Pediatrics recommends that babies be placed on their backs to sleep. This is the safest position for your baby to sleep in. It is important to note that babies should never be placed on their stomachs to sleep.
2. Use a Firm Sleep Surface
Babies should always be placed on a firm sleep surface, such as a crib or bassinet. Soft surfaces, such as a couch, armchair, or waterbed, should never be used for sleeping.
3. Keep Soft Objects and Loose Bedding Out of the Crib
Soft objects, such as pillows, blankets, and stuffed animals, should be kept out of the crib. Loose bedding, such as sheets and blankets, should also be kept out of the crib.
4. Avoid Overheating
Overheating can increase the risk of SIDS. To avoid overheating, dress your baby in light sleepwear and keep the room temperature at a comfortable level.
5. Consider Using a Pacifier
Using a pacifier at naptime and bedtime may reduce the risk of SIDS. If you choose to use a pacifier, make sure it is not attached to the babys clothing or bedding.
Conclusion
Creating a safe sleep environment for your baby is the best way to reduce the risk of SIDS. By following the five strategies outlined above, you can help keep your baby safe and reduce the risk of SIDS. For more information on SIDS and safe sleep, visit CareEywa, Indias leading parenting website.
